RenderMask v5.82.3
Hi guys!
Can someone help me pls with this script? I’ve searched all the internet down and the only one I can find is the new version, v5.90.0 but that works only with VRay.
Thank you!
It’s because it’s a VRay only script. As far as I’m aware, it’s bucket based, so won’t work with a progressive renderer like Corona.
Masking in Corona isn’t the best, but if you set up your Mask Elements, that should be good enough.
maybe I’m wrong but in this video this guys shows how it works with corona https://youtu.be/a3hitlmWYTE
anyway I’ve found another way, I hope that it will work! Thank you.
Hi. In that video hi is saying that the script doesn’t work with corona, and therefore he is using Scanline to render out the wirecolor mask.
