Renderpockets - DIY Helmer Renderfarm Animation
Hello all, this is a test animation using corona to showcase Renderpockets.
Total render time was kept at under 3 minutes per frame (30 fps), a total of 2770 frames rendered under 14 hours using 5 x i7 3770s (renderpockets).
There is some flickering due to the fact that each frame is only using 30 passes at default settings at 1280x720 resolution. Raw render, no post (yeah corona!!)
Hope you like it and the product!
Art
cool :), Just remember to use Path Tracing in secondary solver to remove the flicker, You could also add motion blur and a tine dof effect to add more contrast/depth. good luck
would you like to try UHD cache for the animation? It should not flicker
cool, I will try that, thanks for suggestion!
this is when it sucks to be in south africa, no ikea or easy shipping and payment especially with small companies etc… sigh.
cool animation and product!
can you use alibaba? or ebay
So nice project, i’m waiting for the start, hope my deals will get better in near future and I will be in need of render farm, this will be my choice. The animation also looks nice.
