Renders saving quarter size
Hi! I need some help with a basic animation render. I’ve set up a camera that moves around a pedestal. All the renders are still frames at 3840x2160. They are rendering well in the VFB but when they save as a jpeg they’re cropped into the top left corner surrounded by a black background. As a result, the output of the cropped image is a quarter of what it should be. I assume there’s some output button somewhere that controls the size/cropping? Ultimately, I just want the final jpeg to be full size and fill the black space. Could it be a camera setting?
Ensure the VFB button for test resolution is off (short click).
Notice it will still show the last selected test resolution number (f.e. 50%).
Execute this line of maxscript to be sure it’s truly off (if the UI isn’t as communicative as you’d like it.).
vfbcontrol #testresolution off
Hi could you check if you have enabled the “test resolution” button in your VFB?
This can cause the effect that you are getting for some formats.
Edit: I did not see Lele’s post before sending mine.
This solved it. Knew it had to be an easy fix but just couldn’t figure it out. Thank you!
Cross posting at its finest, eheh.
It’s good we both said the same thing, imagine the embarrassment otherwise… ^^
