Replacing 3dsMax with (?) Blender (?) for archviz
This year I’m going to try and stimulate our European economy a bit by removing as much US companies from my life as possible as every day I’m losing more and more trust in the US.
But the biggest issue I will have is replacing Autodesk, Adobe and Windows I’m afraid, and I will have to put A LOT of work in not only learning how to be as efficient and fast in Blender, but also converting all of my models and shaders.
I wonder if people here did a similar thing and if they regret it?
Archviz is strongly build around 3dsMax and inside Windows, and I feel we are seriously locked in and something needs to change as I don’t want to be US dependent. There a lot of other things that I have to solve as well when I go this route, but this is the first biggest hurdle, and if I can’t solve this one, than there’s no point in going ahead with it.
Like to hear people’s thoughts, gripes, issues. Thanks!
I think the starting point would be OS. In the media I see lots of stories on how to replace Windows with Linux. In my workflow there’s few key applications that don’t work in Linux. It’s not going to be easy.
The convertion of your library could be the main issue.
If your workflow and daily job are based on your 3d library, well this could be an issue.
One thing that could mitigate this is to switch to Vray for Blender but I’m not sure, at the moment, it’s really a functional tool for this kind of job.
In my opinion it’s not so impossible to switch to alternatives but it really depends on how you work and in which way you use the software you listed.
I’m thinking to make a similar swith on my daily job (at home, for my hobby jobs I’ve already done the swith but I recon that it’s not a comparable scenario to your) and I’ve made a plan that could work and it considers to use Vray as bridge from 3dsmax to Blender and the opportunity to open 3dsmax using a tokens based license, so, when I really need to open an old project or a specific old 3dsmax 3d model, I’m able to open it and convert it.
At the moment I haven’t put this on the road as company I work for is struggling a bit and investiments are well weighted…as soon as things will positive change, I think I’ll go to that route.
About Adobe, probably a good alternative could be Affinity (now bought by Canva) that should have a Linux version and you’ll get a well recognised tool in the market. It seems they have now a free license (note that they should track how you use it as training data for the AI of the Canva company…probably there should a way to block that tracing, I dont’ know) so you can test it in advance. Otherwise there is GIMP, Inkscape, Krita and more…a good thread where you can browse some of them is here Adobe / Autodesk / Canva / Maxon alternatives - Latest News - Blender Artists Community
Thanks for the input. I just checked out some core things that I really need Blender to have and I’m suprised that spline modelling/drawing is very very hacky and not well supported unless you buy a bunch of plugins that also don’t really do what I need it to do. I use a lot of CAD plans provided by architects as a starting point, and it seems that that is also not very supported unless you use a bunch of workarounds. I tried to create a mesh from a spline that has some different elevation points and well it doesn’t do what I need it to do at all. I know I shouldn’t port workflows 1 to 1 if you’re going to another software, but this one I can’t replace with a different way of doing things. Second thing I looked at was UVW mapping…there is no regular UVW box map? I’m not sure but I feel like these are things that I can’t go around. I love 3dsMax for its procedural modelling, so I looked into the geometry nodes, but although probably powerfull, if I can’t manipulate a spline to create a mesh that isn’t flat, than I feel like I’m going to lose a lot of time.
The library conversion, I found the Max To Blender plugin but in the end I would probably have to come with my own script to batch convert.
All in all I’m quite disappointed that Blender doesn’t have good spline support, simple UVW mapping, standard procedural primitives, etc… I guess Blender is out of the picture.
I’m going to check out if Cinema4D is an option, which is German apparently. As I’m not opposed to paying for good software, although it’s 3x the price than 3dsMax Indie. I see Vray has better IPR performance in C4D as wel. Going to investigate and report back.
Edit: as for Adobe, I tried Affinity a long time ago, I even had a license but I lost the key, it had its perks. Just installed it again and a lot has changed, need to tinker with it a bit to see if it’s a valid alternative. I need to find a good alternative to premiere/after effects as well. I installed Davince Resolve but not sure if it will be a good match.
Cinema seems a good solution, it’s a pity that they switched to the rent model but anyway…
… Not to force anyone…just to inform people that could interested and that will face the same issues you’re facing…
Spline modelling.
Just reading this I can’t understand what kind of mesh are trying to create but, generally speaking, are you searching for a Sweep Modifier in Blender?
If yes, I think that this could work z-Curve-Sweeper for Blender 3.0+ (Curve-to-Mesh with superpowers) - Tutorials, Tips and Tricks - Blender Artists Community I don’t know if it can cover the test you did…it’s free, so it could be tested and check.
Simple UVW mapping
Standard Blender doesn’t have a 1:1 modifier that works in the same way. Cube mapping actually existing (also Spherical and Cylindric) but it doesn’t have the controls you need. And it’s a destructive operation.
For something really similar to the 3dsmax UVW Mapping modifier there is paid addon: https://superhivemarket.com/products/xyz-mapper?ref=2305
Standard procedural primitives
Are you looking for something like this?
ND Primitives — Blender Extensions It’s free so you can test it.
In my opinion, the worst situation is with CAD plans from the architects…if you can ask the DXF file format, you could be able to import them. If not, it could be really an issue.
As of Blender I’m doing the switch from Maya to Blender. So far it’s quite a pain because you have lots of things that are really different. And there is not on Blender, there are thousands of Blender. You need to configure what you want, you need to find plug-ins (sorry, addons!) for what you want.
I really miss the Grouping feature even if I found a addon for that. I miss the fact that Maya could really use curves (DWG) and surfaces.
That said, I want to do the switch and I need to get used to this other software after many years of Maya workflow. Vray is not so badly integrated into Blender.
Something weird is going on with the forum, constant errors and can’t quote people. Anyway bardo here’s quick video of what I find to be a very handy way to create uneven terrains in 3dsMax from (CAD) splines and still allows me to adjust without having to bake down to geometry if something changes: https://youtu.be/bpAr6Sit8pA
I find spline modelling for ArchViz indispensable. I just very quickly tried Cinema4D and a similar workflow is possible I see, although I need to get used to a complete different way of working, some things don’t seem logic but that’s because I’m used to other 3D software. But I already like the fact that it’s procedural and not destructive like Blender.
Edit: just saw the pricing of C4D and it’s 3X the price of Indie 3dsMax, ouch.
Any reason you’re switching from Maya?
I am not fully sure what Blender is lacking for you. I switched to Blender for the most part from 3ds max a while ago and didn’t really miss anything in terms of modeling. Sure the spline modeling tools are lacking but you can do spline modeling in blender and get procedural modeling done with geometry nodes.
In terms of of box mapping. Yeah there sadly isn’t a strict modifier that enables box mapping but there are a few quick uv unwrap methods like cube projections etc. Or use cube projections as part of the texture/material if that is an option. Or tri planer mapping.
In general I’d not recommend c4d. It’s so much more pricy than the competition and at least when watching a friend model in it I constantly can see weird artifacts for simple modeling/chamfer operations. Left over verts. Or odd deformations.
But this is just based on what I saw someone else do. It has been almost a decade since I last personally used it for anything but just needing to place assets and deliver a scene file to a client.
Though I won’t deny when I had to switch to blender for a specific work project I was cursing a lot :stuck_out_tongue: Hated some thing (mostly the different workflow and the software being more reliant on hotkeys than 3ds max) but since then I’ve mostly abandoned 3ds max for anything besides rendering if I need forest pack and vray.
So I am not gonna pretend everything is sunshine and rainbows in blenderland. :stuck_out_tongue:
Well first thing I tried in Blender was to do something similar to this out of the box and at least just as fast: https://youtu.be/bpAr6Sit8pA and non destructive.
Ah yeah that’s a bit more complicated to do procedurally in blender. I am pretty sure it’s doable through geometry notes but that is a bit more advanced and not plug & play.
Not sure if this does what you’d need it to do but I found this 20$ dollar addon that seems more aimed at loft/spline workflows.
https://superhivemarket.com/products/loft-curves
windows is also from a US company :slight_smile:
That’s why here on the mainstream media, there is lot of talk on how to replace windows with Linux.
Why such hate for the US?
I’ve asked on BlenderArtist forum…let’s see.
Meanwhile, if you need to create a terrain from levels curves, you can use a feature from the free addon called BlenderGIS.
Waiting for a more comparable method, it’s possible to use a similar workflow for procedural modelling of the terrain.
In this way, if you move the curves, the terrain should follow.
Let me know if you’re interested on further news or if you’ve already decided that Blender it’s surely not your candidate…I don’t want to stress you further. :slight_smile:
It’s not about hate. It’s more about uncertainty and long‑term security. Many Europeans are looking for alternatives to US‑based operating systems and software because it’s getting harder to predict how global alliances and tech policies will evolve. Some of the countries the US now cooperates closely with have taken positions that Europeans find increasingly worrying, so people are preparing for worst‑case scenarios and trying to reduce dependency where they can
It’s mainly due to the company I joined recently. Honestly, I like Maya mostly because I’m used to it.
But Autodesk is a no-go and Maya is slowly outdated even if it’s still used in a lot of companies. It’s expensive as you say for C4D.
And finally, I think it’s good for my brain to learn something new. :smile:
Exactly ! In France, for example, it was clearly stated by the government.
It definitely wasn’t on my bingo card that the last presidential election in the US would increase the Linux adoption rate :stuck_out_tongue:
Meanwhile, for those interested on create terrain procedurally using curves, there is an addon that seems able to do exactly this.
A video showcasing the terrain feature https://www.youtube.com/watch?v=Hl-XsiD27kQ and a preview of an optional faster option for terrains https://www.youtube.com/watch?v=25CrE-eXQ3k introduced at some point.
