replacing bitmap with "show map in viewport" causing 3ds crash
Hi the bug is totally reproducible, and it shows every time i do this :
Create a simple box, assign a corona mat and put a bitmap on the diffuse (it works on any channel) then enter the diffuse channel and click on the “show shaded material in viewport” (the button to show the bitmap on the viewport. until here every thing is ok
Now go to the basic options tab, AND put another bitmap on the diffuse (i always pick the bitmaps from my 2 screen, and drag and drop from there to the Capital M of the diffuse channel)replacing the latest one when you do that the material on the viewport wont update to the new one, So You enter to the diffuse channel again and click again on “show shaded material in viewport” and then Corona will crash.
Can’t reproduce it in dailies nor in A7.1. Tried with compact and slate ME.
What 3dsmax version? Do you have the latest servicepack? There was AFAIK a bug in one version that caused viewport crashes with some textures…
Im using max design 2015 with latest service pack, maybe i will do a video with my cell phone to show it.
For me its 100% reproducible every time
Hi, here is the video were you can see the bug, and that im usign a7.1 and max 2015 (latest service pack)
CAn you send me the minidump file from the crash (its location is shown in the “view details” section)
sure, here it is
just checked again, and for me its reproducible at the first try
3dsmax_minidump.7z (509 KB)
ok, I managed to reproduce it. It happens only when using the small box, not the regular large slot in maps rollout. Weird. I will see if I can do anything about it.
Nice :smiley: now i know im not crazy :wink:
fixed
