Hey guys new to this program. Have to pump out some renderings for finals. Saved the file in revit 2015 successfully brought it into 3ds max, i have corona installed as well as Vray for camera use. But first off how do i apply say a wood material to a CLT wall as a start? In revit the material is applied but once you render in 3ds max the rendered image is red with water marks all over it saying the mater is not compatible. Very newbie to this program any help would be appreciated.
You need to apply Corona materials to your objects. If your objects have V-Ray materials applied (not sure how this import-export stuff works), then you should be able to use Corona Converter script: https://coronarenderer.freshdesk.com/support/solutions/articles/5000549705
You can also download free material sets off our website and use them for your objects or create new materials using them as reference:
Sorry, but this is not a 3ds Max training forum. We will gladly provide you with some general knowledge, but you should be able to find tutorials on google/yt easily.
