REQ: Script to change the 24 Mtl from STD to Corona + Multi/Sub
Hi all,
I know, there is a lot of work to do before this, but I’m here to ask you if, someone, can write a simple script to :
() Clean all 24 mat and and replace the Standard MTL with CoronaMtl
) Create on the selected slot a Multi sub/mtl with 10 Corona Mtl
This is very useful for every project and can speedup our workflow.
Just a suggestion…
Thanks :smiley:
(1) is already implemented as a button in my Material Converter Script :slight_smile:
(2): Here you go…
meditmaterials[activeMeditSlot] = Multimaterial numsubs:10
for i = 1 to 10 do(
	meditmaterials[activeMeditSlot][i] =  CoronaMtl name:("CoronaMtl_" + (formattedprint i format:".2d"))
Thank you DeadClown, the the 10 Multimaterial are standard material, not Corona.
