Hi, I have one query, I just installed the sketchup 8 and vray 1.48 on windows 7 64 bit , installed without problems, but I can not move the camera physical values that are in 0.0, shutter speed and those of others, anyone know if there is any trick or something to do before changing these values? thanks.
Re: managing physical camera in vray 1.48
if you have the physical camera enabled… then it sounds like you are experiencing a strange bug! Check to see if any errors show up in your vfs error log, and open the ruby console to see if any errors show up there too!
thanks, I’ll check those errors
no error in either of the two sides had recommended me to look, the truth that no other solution is to give it.
