Request - Movement Speed Shortcuts
We’ve been using a little bit of Twinmotion for animations and one thing they have in their system is a numbered shortcut for the movement speed around the scene, it would be great to see this in Enscape, maybe 1 could be like ‘Walking’ speed, 2 could be ‘Run’ or whatever and 3 could by ‘Fly’ or something? I just find it a hassle when navigating around that I have to flick back to the settings panel and update the movement speed to get to some areas on the site and then flick it back once I am at that location?
Hi @DanS_1 , first of all, have you tried pressing [SHIFT] while moving? This will increase your speed while being pressed. Next, you can also press [CTRL] - this will increase your speed even more. If that’s not enough, you can also press [SHIFT] + [CTRL] at the same time, which will make you even faster.
Apart from that, you can also double click (left mouse button) any geometry to be moved directly there, so you won’t have to adjust your movement speed in the settings for that.
Does this help? Please let me know in case you require any shortcuts above that.
Yes, yes it does! Didn’t know about the double clicking so that’s a bonus!
