Hi guys,
a quick request, would it be possible to grey out incoming connections on nodes?
this way its clear what is connected to something and what is not.
Hi guys,
Sure thing, we’ll look into doing this as soon as possible.
Thank you!
Thank you!
pinging this! hope it can be added because it gets confusing otherwise
Yup, we haven’t forgotten about this, we found a way to do this but it turned out it’s quite messy.
Either way, I’ll start taking care of this now.
Cheers!
ok, thanks! ![]()
Should be available in tomorrow’s builds. Although there are a couple of instances where parameters won’t be grayed out:
1. Alpha and Color tweaks settings on Texture nodes
2. Bercon texture nodes - the inputs and the parameters in the UI are separate controls multiplied by each-other.
I’ve manually checked all nodes so I believe you’ll have no issues but should any pop up, please ping us so we can fix it.
All the best!
