REs aren saved with when rendering on the farm
I’m using the latest Deadline Version and I’m using the “Seperate Render channels” save mode in the Vfb settings.
Rendering and denoising itself seems to be working fine but when it comes to writing out the files it does not save the denoised RE OR the non-denoised original RGB, depending on the mode set up in the VrayDenoiser Render Element. If I set it to Hidden, the only file saved is the original Beauty pass, when I set it to show, the only file saved is the denoised one.
I just realized that no REs at all are saved, just the Beauty itself. Also, when trying to save via the “vray raw image file” save method, nothing at all gets saved. I have tried Vray 3.5.04 and the latest one, 3.6.03, same thing with both versions.
Did anyone have similar experiences yet? I suspected Vray to be the problem, but since no REs at all are saved it sounds more like Deadline is the problem.
found someone with similar experiences using Corona and Deadline, so this seems to be a deadline issue. I hope the support there can help.
