When ever I reset material editor slots I get an error stating --Runtime Error: Cannot assign undefined to Material Editor Slots
This is after I have loaded the custom UI Layout of Max.vray
Seems to only be when I swithc to Vray UI Layout.
Is your custom UI layout from an older version of 3ds Max?
That is notorious for causing problems like this, due to variables & functions changing names or disappearing between versions.
I don’t think so.
Just installed Vray 1.5 Sp6 and the switched UI Layout to Max.Vray
There was a fix for this somewhere on the forum, not sure where I found it now, but I had this problem before and it was resolved. Do some searching and it should turn up.
It fails for me, too!
I found a solution:
