Resolution Preset <from camera> no longer working
I’m finding the Vantage - Common Settings - Resolution - Preset <from camera> is no longer working. I now have to set the resolution manually. It did work a few updates ago. Currently using Vantage v 3.1.0. 3ds Max v 2022.3
Hi neil_clark,
Is this happening when rendering animation from Live link or from a regular Vantage session?
Alexander
Ya… Happening to me too. Rendering a still. From camera doesn’t set the aspect ratio.
Hi Luma3d,
Are you using the <current view> option in the Camera name dropdown?
Hi Alexander,
I’m rendering stills from regular Vantage session.
I note your screenshot above. When I change the Camera name from <current camera> to the name of the camera I’m using, the Resolution <from camera> changes correctly. This doesn’t seem to be the most efficient workflow since I will need to make two menu selections to get the correct resolution?
<from camera> isn’t respected only in the first attempt. If you exit and re-enter Render Setup (with <from camera> checked) - it starts to work correctly
Hi guys,
Yes, I agree and we do have plans to improve this in the future.
Alexander
