Hello ,
I have prepared different settings, all the same. But now the collegues come back with different resolutions for Panorama.
How can I change the Resolution?
from
2048 x 1024 Pixel
to 8192 x 4096
Thank you
Heinrich Boldt
PS: Thats my screen, not one of my collegues
](Microsoft OneDrive)
Have you looked under General settings | Capture | Panorama | Resolution - there is a drop-down - low = 2048, normal = 4096, high = 8192
You will need to re-render at the higher setting.
@Gadget_1 already mentioned what you could please check and do. In case the resolution is set to high, but panoramas are still being exported on low resolution, please let me know so that we’ll troubleshoot the cause behind this.
If you haven’t already, also check out our dedicated Settings Presets knowledgebase article here, more specifically the section with the title “How To Share Presets With Others”. This way you can make sure that the settings from one machine to the next are the same.
