[RESOLVED] CoronaSky with projection dome broken ?
I want to use the dome projection with a hdri and strange result here. Can you confirm a bug ?
Hi there, can you share a test scene? It’s working here. What version are you using?
With dome mode you have to keep the radius/camera values somewhat realistic. A too small radius may end up looking like what you have, try increasing it.
Damned no success here using the last version of corona. Here is a simple scene with a basic setup : a sphere a plane and a sky with a hdri. Thanks
It’s the Corona bitmap that is doing this, you will need to remove it and it works just fine.
(Report ID=CC4D-705)
ok thanks Beanzvision
