I updated my Vray 5.2 Version from “vray_adv_52024_houdini19.0.657_574f020_22092”(12. 07.2022) to “vray_adv_52024_houdini19.0.657_f075612_22116”(05. 08.2022).
With the new version some shaders behave totally different. Some shaders produce different diffuse values and some different glossiness values. I mostly use FileNodes, Triplanar’s, LayerNodes, and ColorCorrections.
Is there something between this versions which was changed and could lead to this behaviour of shaders in the newer version?
Unfortunately I can not even check the changelogs because they’re none for the Houdini Nightlies as far as I know…
Somebody having the same problems?
Cheers
Tobias
Nightly builds are usually never guarantee you consistency, that’s why there are “stable” nightlies.
Could you post any images/scenes showing the differences? Our automated test scenes do not show any differences…
There was a but though in the builds from 4th (or 5th) with the particular bitmap plugin parameter export, so
there is a chance you’ve just updated to the build with that issue.
Yes, this looks like it, color_space parameter was exported wrong after some Core changes, it should be fine now, could you pls try some more recent build?
And sorry for that… but such things could happen with nightlies…
Yes I can try recent builds soon.
No, it was my fault to grab a “unstable” nightly in the middle of a project, I’m well awared of it accually but sometimes my brain doesn’t work how expected
Cheers and thanks for the help!
Hi @bdancer ,
sorry for the late reply. I testet the scene with the newest nightly (V-Ray for Houdini number:22131 hash:26b373e from 19 Aug 2022 01:30
V-Ray Core 5.20.24 [493f4a2c] from 15 Aug 2022).
Seams to work with almost no change to the older releases.
One material is different and I think it must have something to do with an interpretation of BlendMtl / Layer Texture / Distance Texture / Triplanar. I guess something was changed in the builds since then. I can live with that since this brightness shifts are no more.
Happy weekend!
