tomorrow morning I take a look to the new Corona Render 10 on my windows machine with latest C4D release.
I was trying the new clouds color model and camera size settings, so I created a simple scene with a sky with clouds and sun as well.
I got continue C4D windows freezing with interactive rendering during the calculation of the second GI…every time…I killed the app…
I installed on the PC due to test, I not installed yet on my production machines.
Anyone experience freezing?
I tried with simple scene and a complex scene underwater, many second GI freezes…
Even if it’s a simple scene and might be easy to recreate - you should include a file so anyone can reproduce the behavior with the exact same file and steps to check and confirm.
oh…very easy. I reproduced the freeze without problem. Take a look into this video.
https://www.c4dzone.com/clienti/freeze.mp4
Usually I play with new Corona Render in this way, by randomly click into some settings for test…
ps: sorry for mouse movement delay…camtasia software grabbed in a strange way the mouse…
Is Bloom and Glare on when this happens?
yes…the bloom and glare has been activated few seconds before the freeze…
at 1.17 I turned on the Bloom and Glare, at 3.16 I activated it again (due to the still present bug about bloom and glare that turning off it self)…and corona died…
Hi there, are you able to share a test scene with us where this happens? Also, can you please test the latest V11 daily build to see if this resolves your issue and let us know?
https://forum.corona-renderer.com/ Chaos Corona 11 for Cinema 4D daily builds - Changelog
Hi there, have you managed to test the latest build at all? If so, is this still happening?
Based on the video, the freeze was from the camera physical size being enabled whilst IR was running. This was a known issue and was resolved in V10 hotfix 1.
