I have a bunch of packed objects that I wish to (in the shader) vary the hue of per (packed) point. What’s the suggested workflow?
The way I’d approach it in Mantra (very crudely) is
- make random ‘shift’ attr with shift value -1 to 1.
- take Cd (or color map) input in shader, RGBtoHSV, then add the ‘shift’ value, convert back to RGB and plug into the shader.
Just want to add, that you can also use the sampler node to get a random value for each of your packed primitives, this way you don’t even need to write any extra attributes into into you geometry.
Sampler node > random by polyShell > remap values to Hue shift wanted > hsl_hue_offset
Hey, yes but it also depends how the mesh is packed.
The connectivity still can be better when you need more separation in the mesh. They both have its uses
