I don’t seem to find how to use the material library in Houdini and although the info talks briefly about it, I don’t seem to see the documentation on the subject.
Are these organised as Galleries? Special python panel?
How do I use these MAT files?
Can someone point me in the right directly please? Thanks in advance.
Hi @jordi_bares1 , new V-Ray material library is available only on windows for now. You can find materials in Material Palette tab. Be sure V-Ray is enabled in Edit > Preferences > Rendering menu.
In some of materials created by the gallery presets I have found it referring to textures using the variable $VFH_ASSET_PATH.
Where that should be pointing? I haven’t found in our vray installation an asset folder, or a folder with textures, probably we are missing something?
@miko3d It works fine on Linux. Just gotta run the installer on Windows and then steal the files and put them somewhere else.
Then set VFH_ASSET_PATH and HOUDINI_GALLERY_PATH accordingly.
