[RESOLVED] Transparent Ground Material: Product Rendering
I am preparing a transparent ground material for the purposes of product rendering, you can see an example in the attached image. I have also attached a Max archive (.zip) with a material set-up.
However, I am not entirely clear on whether my implementation is accurate with respect to the reference. Please advise?
rayswitch.zip (775 KB)
The problem I am having now is that if my implementation is correct, then how can you cut-out (fade) the reflection on the ground?
^falloff map in the ‘reflected color’ channel of the ShadowCatcher material
Except falloff is radial (blue), is there a way to get linear (red) falloff from the camera?
^gradient tex map (coordinates: environ > mappin: screen)
RGB offset to manipulate fade position
Corona Color Correct > curves > equalize
That’s what I call self-support! :smiley:
Another option would be probably using the Fresnel IOR for your reflective ground plane. (values closer to 1 mean less reflectivity on facing angles)
Haha, had to keep moving^
Yeah, I experimented with this and it is a good option too +1
I would say that a material like this one would be good to include in the material library, but due to the additional set-up required in the render setup dialog (overrides) it could cause some confusion for the uninitiated.
