the twoSided Material does not work with (packed) Alembics - just one material is rendered for both sides. Is this an easy fix?
Hello @ronald_a ,
this seems to work as expected on my end. Could you please share the Main Menu → V-Ray → About V-Ray information.
Admittedly I’m usimg a very simple scene so there might be something particular going on in your setup that is breaking the assignment. If possible, sending the scene over would be the fastest way to figure things out.
Best regards!
V-Ray for Houdini, build 8689 / 0ca3844
V-Ray Core, 4.30.03 / 7aa6feac from Oct 2 2020
Hello @ronald_a .
I’ve tested with the same build and the Two Sided material seems to work as expected. I’ve attached my file below - could you please check things on your end too ?
Best regards!
forum_abc_2Sided.zip (39.4 KB)
Ok, this really seems to work, I tested it in your scene with my abc. so there seems to be something wrong on my end. will figure it out. thanks for the fast response.
