(Resolved) UV randomizer with attribute as seed
What’s the best approach to randomize uv of scattered elements? In VRay uv_random node I tried all the different seed options but nothing happens. UV are still the same.
Is there any way to randomize using an attribute as a seed? a different id attribute for each box in this case - see attached.
Thanks!
The uv channel name node has an offset u and v inputs, you can fetch your attribute with vray user float and hook it to these :slight_smile:
Please, post V-Ray 5.x related issues here https://forums.chaosgroup.com/forum/v-ray-5-for-houdini-beta.
