Hey all,
Sorry for the dumb question but I am stuck on achieving a simple task, UV mapping in the shader level.
Is there a way to cylindrically map and have have some kind of size controls?
I can see camera settings but I do not want it to be a cam projection.
Best,
Jim
You could use MakeTransform VOP to control size of Projection UV with type Cylinder. Check the example bellow if it will work for you.
cylindricalMapping.rar (157 KB)
Hey Georgy,
Thanks for the reply, I can’t download the file, it says the page is down.
This site can’t be reached
The web page at https://forums.chaosgroup.com/filedata/fetch?id=1086931 might be temporarily down or it may have moved permanently to a new web address.
ERR_HTTP2_PROTOCOL_ERROR
Oh so you can use Houdini vops in a vray shader ??
Which other ones can you use?
There is a projection UV node with cylindrical projection type.
Well I think, only MakeTransform VOP is supported, at least can’t think of another.
Yep I got that far, I was just struggling to do more complete uv transforms at shader level. “MakeTransform” usage completely solves this for me.
