Is the ‘randomize each tile’ function exposed in the additional parameters rollout?
Corona version: 6 (DailyBuild May 28 2020)
Full-speed, Non-debug, MaxSDK 2020
Build timestamp: May 28 2020 09:00:20
UV tiling stochastic ?
Negative
This is correct, the checkbox has a different name than in the UVW randomizer UI. I guess we overlooked this, I will report it.
Thanks,
Rowan
(Internal ID=519488083)
Yes this was my mistake, I had used a linear float controller and not a boolean controller to enable / disable the parameter. Thanks!
