for some time now vfb is acting weird. The issues I see are very random and sometimes only solvable by restarting houdini. I have the following issues.
- hitting the renderbutton/shelf renderbutton and nothing is rendering (no vfb popping up, no rendering even if vfb is opened)
- ipr button in vfb not working
- hitting the ipr button on the tool shelf --> vfb disappears. I need to hit show vfb to bring it up again to see ipr rendering
these issues are so random and even happen with newly started scenes/houdinis that there is no way I can give you an example scene (and I’m not sure if they are scene related at all - hence restarting houdini works). Good thing is, that it happens so often (on other machines here as well), that you should be able to spot them if you just play around a little.
yeah, i reported it fews weeks ago…
One of the super annoying behavior is the render not being stopped/canceled when i close the VFB…,that stuff will just keep going and running in background, restarting the render, and running again. Unless go to toolbar, show VFB and stop with with Stop button:face_with_spiral_eyes:
We’re aware of those, the dev team is trying to track down the problem. Not much I can do at this point other than apologize for the silly issues - I too hope we’ll have them resolved soon.
psanitra, we could stop render on VFB close, then one day one will render smth for some hours and then accidentally close VFB and will report that render should not be stopped.. I could add an option for such behavior.
At the moment you need to open the Options → VFB Settings → History tab, select “Enabled” and specify a folder. We plan to hook up the “Use Project Path” option to look at “$JOB” in the near future.
