We’re running into a big issue here rendering volumes. Every reflective surface with a glossiness value other than 1.0 that reflects a volume with fire emission is geting this circular artifacts. This artifacts come from the “Emission” in the fire and they apear to be the light grid used on the volume.
Disabling the Emission to get around the isue is not a solution too, as surfaces that also have a diffuse component will have a lot more noise.
Can you make this light grid spheres invisible to specular and reflections please? There is some urgency to this as we have a deadline coming very soon, and all our renders are coming out with artifacts.
Volume reflecting on ground with a 1.0 glossiness:
This becomes quite slow to render, as now the GI has to do all the work.
I think we all agree they should not be there, the light grid should emulate only diffuse lighting, and I imagine the solution is quite simple, the Fire Emission grid lights should be invisible to Reflections and Specular. Is this possible?
Sorry, I misunderstood that you have already tried turning the fire lights off. Seems like in the Houdini GUI the option is named differently than in Max and Maya.
So yeah, making the fire lights NOT affect specular does work, but we need to figure out if there is a valid scenario when someone would need specular with the fire lights.
Will ping you when we change it. Which V-Ray version do you use? Maybe this would need to be backported into V-Ray 4 as well?
Not sure I would ever use the grid for specular, it’s a grid, even were cranking up the grid resolution it’s still a grid so the result will still look a bit strange.
Alrighty, so in tomorrow’s V-Ray 4 and 5 nightlies, the fire lights will not affect the specular by default.
In Phoenix and V-Ray for Max and Maya I also added a hidden script option named ‘firelightsspec’ that would allow re-enabling this if anyone needs it - if this option is needed for other hosts, it can be added as well.
@Svetlin.Nikolov that’s is great news, this is higly appreciated, will give you feedback tomorrow as soon as I get my hands on the new build. Thank you!
