Hi guys,
I am running into a small issue when trying to get vray 5 for houdini 18.5.408 installed. I am using the supplied package file to load vray. when I do this it works fine and loads correctly, renders etc, no problems. However, when I add the sidefx labs tools to my houdini path I start getting conflicts and I have tried appending and prepending and what not but each scenario raises an error. As soon as I take out one or the other in the config one or the other works fine, but never both at the same time.
The main error when I append the vray path is:
Error while parsing a menu definition file: “../vfh_home/MainMenuCommon.xml” cannot find element 'h.create_mantra_pbr" needed for ordering of ‘vray seperator’. Cannot find element ‘help_menu’ needed for ordering of ‘vray_main_menu’.
I am running Houdini 18.5.408 on windows 10.
Thanks.
Best, Christian
