(Resolved) vrscene indie
I’m new to creating vrscenes and my first attempt gave me a warning that I couldn’t create a vrscene in Indie. Is this true? Are there any tutorials that can help me learn how to create vrscenes? Finally, can I create a vrscene with volumes and grid shader?
Hello @gregfed , I guess you are using the official V-Ray for Houdini Update 1. I think this restriction were canceled by sidefx some time after the release, you’ll need to update to latest nightly build in Chaos . If do not have access to nightlies will need to write to support@chaosgroup.com
> Is this true?
Vrscene export from Houdini Indie is enabled only for some latest Houdini 18.x. For all the other versions it’s forbidden by SideFX restrictions.
It’s just a parameter on the ROP.
Of course you could.
Is there a .vrscene export from Houdini Indie using Houdini 18.x or later?
Is it the same for V-Ray 5 for Houdini?
Hey @flat ,
yes, VRScene export should work with Indie. The option is under the V-Ray Renderer ROP’s “Export” tab.
Best regards!
Thank you.
Please describe in System Requirements. It’s a big advantage.
https://docs.chaosgroup.com/display/…m+Requirements
Hey @flat ,
Thank you for heads up - we’ve updated the docs page.
Best regards!
