Restore Error
I want to restore a sim but i have the “Restore frame is before the simulation Start Frame”. How can i make it works ?
Maybe change the Start Frame :slight_smile: What is the Start Frame right now and from which frame are you trying to restore?
What i want is to continue a sim that has been stopped at the frame 900. I did that before with the restore button but this time it’s not working.
The frame frame is set to 0.
Hmm, only thing I can ask is whether you first moved the timeline to the frame you’d like to continue from. Otherwise it could be a bug and you should drop the scene to Support if possible.
Cheers!
The problem has been solved when I reboot my computer, cool !
