It would be great to have an option to reset replaced material in enscape material editor to its original setting, texture etc. from CAD software.
Submitted on AHA Ideas (ENSCAPE-I-1480).
Status: declined
Can you elaborate a little more on the situation you are facing?
Which host application are you using?
Which steps did you perform when a material change happens that you want to revert?
Submitted on AHA Ideas.
Hi, of course.
I work in Archicad. Archicad has its own materials, foten with low res textures and poor quality.
After I finnish modeling, I want to make some renders. So I start with tweaking with materials, add some bump, some reflections etc.
In Enscape material editor I have an option to replace native Archicad material by Enscape material from Enscape library. So at some moment I replace for example “white plaster” with Enscape material.
After while I realize that inital material was better for my need. So i want to revert “white plaster” to its orignal version - native Archicad material. But theres no option to do that, to switch back.
Submitted on AHA Ideas by Václav Slovák.
AHA Ideas status: Declined.
Set during AHA Ideas to Discourse migration.
