retail shop
Hi to all, this is my second time to post using Vray Sun and Physical Cam
no PS…
As always C&C are welcome…
Mabuhay Vray users…
chill
Re: retail shop
Hi chill. nice render as always, but it will be a little bit nicer to make the render a little bit sharper.But overall its something that i try to emulate.
What i want to ask u is where do u get all ur clipmap trees, or do u make them urself?( and how to use them in v ray) I already know how to make a “face me” people in sketchup but still cant figure out how to make clipmap trees/plants.( their outlines appear when u render them.)
Thnx and Best regards.
Re: retail shop
a bit flat and washout for me chill. are you using the old version of vray or the updated one?
Re: retail shop
hey chill, could you refer me some link tuts for clipmaps?
i really know nothing about it. ::slight_smile:
hehe, that could really save ps postprocess.
thanks.
/migz
clipmapping
hi Migz here how it goes…
First make sure you have a difuse and alpha chanel of a Jpeg image file
and also a Png file with transparent Background
After that you import the Png file image in SU as image, explode it and group it or make it a component
Link that Material in Vray, you noticed that when you export a Png file in Su and exploded it, you get a reflection and refraction when you link the material in Vray, We dont need this reflection and refraction in clipmapping, Just removed it
After removing the reflection and refraction, click Difuse layer then click the M in the color tab, and change the type into bitmap, then load the Jpeg file image.
Next cllick the M in the transparency tab and load the Jpeg Alpha Chanel Image then invert it..
Click the Map layer check the background tab, click the M and load it again the alpha chanel then invert it..
After those image are loaded, update the Material Preview and its Done..
Re: retail shop
nice tut man.. can’t wait to try it.
thanks, i really appreciate it. :wink:
Re: retail shop
thanks also chill 4 d quick tutorial regarding clipmaps. Pls. bear with me with my another question. how do i make an alpha map in ps? :-\
Thnks and regards.
Re: retail shop
hi chill,
Good render there chill, but i think its not quite matching with BG.
its really a complex scene you have i assumed..
Regards,
VD
Re: retail shop
figured out already the alpha map issue and the clipmap trees in v ray works like a charm.
Many thanks to chillrender for the quick tutorial. BIG help!
Keep chillin..
Re: retail shop
master chill,
one heck of a tutorial you got there!!
you really are a great teacher. hehe.
salamat ng madami.
;D
