Retroreflection / reflectors in V-Ray 3ds max
Hi.
I’m trying to create a reflector material, inspired by a setup by the great Darby Edelen done in Redshift, but I don’t really know enough to get it working in vray in 3ds max.
This is the Redshift setup:
ZxmOyOq
But I am failing in V-Ray.
My current result:
v2ZTzBz
I have tried many combinations but I have little idea what I’m doing, don’t fully understand the original setup. Anyone got any ideas?
Thanks.
You could use a falloff map in fresnel mode as your reflection map and just swap the colours so it’s stronger at the facing angle and not the sides!
A googled AI response suggests the attached method…maybe that will work.
Some years ago i was given this OSL code snippet by Vlado when i asked for retroreflector solution in Corona. Unfortunately it didn’t work for me, since Corona does not support normal maps in any other mode than tangent, but i think it should work in Vray, so give it a go. Unlike AI solution a message above, this one should be much closer to how retroreflectors work in real world.
Yeah that appears to work nicely. Thanks :slight_smile:
The AI response was, as expected, not really worth reading…it was just a quick search before I rabbit-holed more this morning.
Ah lucky you. I wish it would work in Corona too. I spent good portion of the day trying to interrogate AI if it could make something that would work in Corona, but it just kept spitting at me code snippets that all produced garbage results :frowning:
Hehe, the terms AI and garbage are becoming very close companions.
Although, to be fair, I just tried Claude for the first time, to try to animate some numbers in a Three.js model, and it did exactly that, with a coherent and helpful explanation. Maybe I got lucky :stuck_out_tongue:
I don’t know if it’s luck or not, but personally i never had much luck with AI regards to 3ds Max help, particularly on maxscript related topics. I see people are vibecoding mind blowing stuff left right and center, but all i can get, it’s non working trash. Maybe i just don’t know how to prompt it, or i use the wrong models (usually it’s whatever google offers for free).
Yeah I tried using something ages ago…maybe chatgpt, to get a maxscript for something.
It was just torture and iteratively worse, so I gave up.
I think it has become better by orders of magnitude, given the amount of stuff now being done with it. I’m just using the free Claude version and so far, no problems, with each tweak being done without issue, so maybe you’ll get lucky with it too.
Thanks, this seems to be working well.
All solutions not transforming normals are not really good enough to be honest, but thanks for the contributions still.
3dsmax_qefj3Wf4PK
