Reverse the reading direction of one of the layers
Hello, I’m having trouble performing a simple operation. Reverse the playback direction of one of the layers. I can’t reverse the IN and OUT points.The goal is to make two layers and reverse the reading direction of the second to go back and forth around a stand.
If you could point me to a short tutorial on this topic, please.
You basically wish for an independent playback duration per layer, is that correct? There’s no direct way of doing this at the moment, only globally (for all layers) via the Repeat Mode button (check screenshot). I guess if you ping-pong the layer you want, save it as so, and use it in another composition, it should work for your case.
