Revit 2019 Enscape - Export to Web Standalone
I’ve noticed that when using the web standalone export function, the model renders fine but the colors are super saturated…is anyone else experiencing this? These are PC Win 10 Snips from same monitor. Am I missing a setting? I’d love to be able to share something with my client which is closer to what I see on my screen (in terms of color…more or less). Please help! {I’m not sure this is in the right forum section…so please move if need be…thx!}
Currently, because of technical constraints the web standalone is basically running in draft mode. So, unfortunately the result is as expected. We are working hard on improving the fidelity of the web standalone.
In addition to that however I’m quite sure that the settings used for the web standalone differed to the used for the comparison screenshot. Most likely contrast and or saturation were set to a much higher value. You might want to try to reset all settings before exporting and see if that resolves the issue.
Thank you both…meantime I may just use the “white model” setting to send to clients via web export until it gets sorted out (assuming I can).
@mw4_1 , yes indeed, you can export Web Standalones with White Mode active. :slight_smile:
