cecarch
February 28, 2023, 1:28am
1
I’m trying to use Revit 2022 with Enscape. I reloaded Revit and added the Enscape updates, but I still don’t have access to Enscape. The Enscape icon is greyed out. See attached image. Have you come across this issue before?
I would appreciate any help.
Thanks!
Cecarch
I have this graphics card on my computer
Does this card work with Enscape?
It is indeed supported - Can you please just also transfer your log files that you’ll find here:
Enscape main plugin log files:
C:\Users%USERNAME%\AppData\Roaming\Enscape\Data\Logs
Revit plugin log files:
C:\Users%USERNAME%\AppData\Local\Temp\Enscape\Logs\EnscapeRevitPlugin
Beforehand please also try re-installing Enscape for “all users” on your machine as detailed here:
https://learn.enscape3d.com/blog/knowledgebase/getstarted/#advanced
Last but not least please also update your GPU drivers in case you haven’t yet.
If the above makes no difference, simply attach the logs via a .zip file for example.
here you go
logs.zip (5.9 MB)
here you go
enscaperevitplugin.zip (82.3 KB)
I have uninstall and reinstall Enscape and Revit. I am using the latest drives .
