Revit: Change the category of the assets from "planting" to "furniture"
I would recommend changing the categories of the asset library objects from “planting” to “furniture”
(except the actual planting :stuck_out_tongue: )
On the one hand, Enscape furniture can not be hidden or shown by using one categorie (eg. if you don’t want to see the REVIT planting but the furniture).
On the other hand, we developed a system that makes it possible to load furniture from a linked project into another project by using the “furniture” category.
However, this only works if the objects are assigned to the correct category.
Or is there any explanation for them being there?
@thenewless , this subject is still a work in progress and will be adjusted over time soon to increase usability and workflow. :slight_smile: Still, if you like, I can file your wish as a feature request accordingly.
The thing is different offices will want to use different categories for the items.
I’d like the fact that Enscape assets are on the planting category because they can scale. We need to scale persons and plants all the time, and even for props that might be very helpful (scaling props like vases etc).
It all depends on how you’ve set up your standards and workflows.
For custom assets, it’s going to be helpful to be able to determine the category.
Is it possible to add a sub-category to an Enscape family so that I can “filter” enscape trees and people in the main model?
Maybe this can be done will labels?
+1
Hi @seysearles
Thank you for the suggestion, I have forwarded this as a feature request on our agenda
+1
Oh yes please! I spend quite some time figuring out why in the world all my furniture disappeared! :slight_smile: The planting around the area I’m building is quite dense and to give it the proper look through the windows I’m using quite a few models (probably too many, but hey…)
This means my model is fairly laggy when moving around in 3D view. So I disabled planting - because that kinda made sense until I used Enscape or rendering fixed images. But then I lost a lot of my furniture and other models :frowning:
Sad… Hopefully this could be fixed! :slight_smile:
I use filters to organize the assets in Revit, but in reality I would prefer to have them in the “correct” families like… they are in the asset library in Enscape!! Come on guys, work it out please!!
