Hello, I am having an issue with Revit version 2022.1 and Enscape.
When I try to input a Mark to the material in the identity tab, Revit freezes.
If I open the same file in a later version of Revit, 2023, it works fine.
I am running the latest version of Enscape 4.0.2.11 and Revit 2022.1.
Hey @iteachrevit
I tried reproducing the issue with Enscape uninstalled and it still froze. Can I ask why do you think it’s related to Enscape?
You are correct.
I believe it was created after I installed a Revit hotfix.
Revit 2022.1.6 Hotfix
I do not think it is related to Enscape.
Please mark this as solved.
