Revit to Sketchup
I’m not a Revit user, I need to convert a Revit 2018 to Sketchup model, is there a way to do so without owning Revit?
I dont think so, you need Revit to export it. But theres a trial so you could use that.
And if you do manage to get the trial - export the model from inside a linked model rather than the main model and it will preserve your materials (assuming you’re exporting to 3d dwg, which can be imported into Sketchup). Exporting from inside the main model means everything will come in white. It’s a wierd quirk with Revit, and makes me think they’re intentionally trying to discourage people from moving to Sketchup. There are other custom converter plugins out there such as the Kubity one that will attempt to turn your revit model into a sketchup model, but they mess with the geometry a lot trying to optimize things, so the results are pretty crude.
(To export from a linked model - create a new blank project in revit and link your main model into it. Then open a 3d view with everything on you want and materials showing (also detail level set to fine), and export to 3d dwg. There will be a couple dwgs, one for the main model and one for the linked model. Depending on the size, it can take several minutes, or even over an hour, to import into sketchup, but the geometry will be clean and it will actually create groups/compoments for objects like doors and windows, though many of them are duplicates unfortunately)
You can also just create a phase after your new construction phase and export from it, for some reason this maintains the materials too in my experience. IE so you r building becomes existing.
