RGB Primaries priority in 3ds Max 2026 with Custom OCIO Config
Hi Chaos Team,
I have a question about texture RGB Primaries evaluation order when using a custom OCIO config in 3ds Max 2026.
Previously, V-Ray resolved RGB Primaries based on filename suffixes (e.g., _srgb, _acescg), and used default settings only when no suffix was present.
In 3ds Max 2026, however, Max’s “Input Image Files” default setting seems to override V-Ray’s suffix detection. With my custom OCIO default set to ACEScg, textures explicitly named _srgb are being forced into ACEScg, causing visual mismatches.
[Steps to Reproduce]
Set 3ds Max 2026 Color Management to OCIO with a custom OCIO config.
Set Input Image Files default to ACEScg.
Load a texture with a _srgb suffix (e.g., texture_srgb.png) into VRayBitmap.
The resolved RGB Primaries become ACEScg instead of sRGB.
[Questions]
Is Max’s default setting intended to take precedence over V-Ray’s suffix detection in 3ds Max 2026?
Is there an option or recommended pipeline workaround to restore suffix-based priority?
Thank you!
First of all, which V-Ray version are you using?
Second, I cannot reproduce this behaviour. I have a feeling something else is happening: for example, bad syntax in the flags, which leads to V-Ray using ITS OWN default rendering RGB primaries, as stated here.
For 8-bit images, only the “_lin_srgb”, “_srgb” and “_aces” flags are supported by the way; I’m not sure if you are trying to use something else.
I̶ t̶h̶i̶n̶k̶ 3̶d̶s̶ M̶a̶x̶’s̶ I̶n̶p̶u̶t̶ I̶m̶a̶g̶e̶ F̶i̶l̶e̶s̶ a̶f̶f̶e̶c̶t̶ o̶n̶l̶y̶ r̶e̶g̶u̶l̶a̶r̶ B̶i̶t̶m̶a̶p̶s̶, n̶o̶t̶ V̶-̶R̶a̶y̶ o̶n̶e̶s̶.
Thank you for your reply.
I am using V-Ray 7, Update 4 Hotfix 1 (1DR 2).
The textures I am using are 8-bit images with “_srgb” in their file names.
Okay. I think I reproduced it - not with the Default, but with the specific format rules (.jpg in my case). Indeed, it seems to override the _srgb flag and apply whatever was set in the rules. Will forward it to the devs.
EDIT: Removed all format rules, leaving only Default - now I reproduce it the way you do. Logged the issue (VMAX-15856) for dev investigation.
Thanks for your support. I’ll be waiting for the fix!
