Rhino 7/ Enscape Custom Asset Export Error
Rhino 7 / Enscape
I have a large architectural model with many Enscape assets and a handful of custom assets (low poly plants purchased through Globe plants).
I loaded and placed these custom assets onto my office workstation and cloud server, but I receive an Export Error if I try to work on this file on my home PC.
I have tried to reload the asset folder, but still no luck.
Where is the best place to store custom assets if working on multiple machines?
@s_whalen , thanks a lot for your post.
Right away, storing the custom assets should not be a problem the way you are doing it currently, but the actual home PC here at hand might be “at fault” instead. So i this case please also submit us a support report from that home PC as detailed here: https://learn.enscape3d.com/blog/knowledgebase/using-the-feedback-button/
Beforehand/alongside please also feel free to check out our comprehensive corresponding “Custom Asset Library” knowledgebase article here:
https://learn.enscape3d.com/blog/knowledgebase/custom-asset-lib-2/#ed
After clicking on that link to get to the article you can scroll down just a bit further to get to the “Configuration of Custom Asset Editor” part, which I highly reccomend checking out in detail especially since it also covers one potential cause for your error message here at hand.
Once more thank you in advance for any further replies and/or the support report itself.
