After I installed Enscape, I can no longer delete named views. It also slows down my Rhino significantly.
Sorry to hear about that. You are running our latest version too, correct? It would generally be very helpful if you could briefly send in a feedback report, briefly elaborating your issue in the submission form, and/or adding a link to this thread so that my team knows what the problem is to troubleshoot this accordingly.
Also, when it comes to the slowing down, maybe you could share your system specs with me too? If you’re using a larger project and/or your system meets our lower recommended specs only, I can recommend to lower the Rendering Quality in the Visual Settings (General tab).
Thank you in advance! ![]()
