Rhino crashes when trying to render sketchup imports
I’m using some simple imports from sketchup, photo mapped cars…my file size is relatively low…about 65mb. anytime there is a sketchup object with mapped material vray seems to dislike this and crashes…I get a Microsoft Visuall C+++++ warning and it shuts down. Any advice or why this is happening?
Re: Rhino crashes when trying to render sketchup imports
check the images on the materials - make sure the image maps are RGB (not index or CMYK or grayscale), and also not progressive scan jpegs. if the images are ok, you may have a bad mesh, try hiding all but one of the imported mesh objects, then render, to find the bad one.
