Rhino Live Link Port Mismatch When using Vray Live Link, but not when Using Chaos Bridge
I am having an issue where I cannot get the live link between Rhino and Envision to connect when V-Ray is installed. No matter what port I set in Rhino, the Envision port is always 2 lower than the V-Ray Live Link port. However, when I install Chaos Bridge, it connects as expected.
The first time I used Envision, I installed Chaos Bridge, thinking I needed it, without realizing it would disable the V-Ray install, which I believe may relate to this issue.
Ok, I seem to have fixed this by downgrading the Rhino Vray from the latest version to 7.20.2
Hallo,
Yes, Envision currently is compatible only with specific version of V-Ray as stated in the documentation here Live Link
I am glad to hear you managed to resolve the issue.
We are working on compatibility with the latest V-Ray releases.
