Same texture, left Vray material and right Rhino material. Was no problem at VfR2.
Hello, Micha,
Do you mean that the rendered models are identical before the color correction?
Could you please send us any sample model which exhibits this behavior?
Kind regards,
Peter
The internal color correction of Rhino material textures is missing only. Nothing special. (At VfR2 it was working.)
There are some discrepancies between Rhino materials, converted from Rhino materials, as well as standard V-Ray materials. I’ve created a task about improvement of the autogen material code. This should hopefully be resolved in the next big release.
Thank you for pointing this out!
When will the next big release?
thank you!
V-Ray 3.6 for Rhino is scheduled aproximately a couple of weeks after the V-Ray for SketchUp update (which is coming very soon).
Kind regards,
Peter
