Rhino Model won’t show on Enscape
Hello, new to Rhino here. If I add an object in from the Enscape library, it will show on the Enscape viewport, but my actual building model does not. Does anyone know how to fix this? Any help is appreciated!
I’m sorry to hear about that @french56 - In the very first instance, please make sure that the project scale is set to centimetres and even more importantly, make sure that your project is located in around at least close proximity to the initial project location which you would be in when starting a new project for example. So, otherwise put: If your project is too far away from the default-centre location, then this can cause all kinds of problems within Enscape itself.
Should that not do the trick, then please also make sure that your graphics card drivers are up to date and send us a dedicated Feedback report with your logs - you can also feel free to include a link to this thread in the Feedback Report submission form itself for context.
Thanks a lot in advance!
