Rib boat
New boat Done for a client, will be a range of sizes from 5 to to 10 ft as a new business. done in 3ds max
render times were 3 - 4 minutes for each image with corona 1.4 last daily build
Too much aliasing on edges. I wonder if it’s from denoising. Rawalanche said that there is bug, which causes aliasing from excessing usage of denoiser. In that case i would try to render for a bit longer and reduce denoiser radius.
o no that is not a corona error, i purposely added sharpness to the model and bumped up contrast in Photoshop, the client wants it like this for his website. says he will be using really small versions of this so, it was deliberate so worries, corona was perfect.
