I used to be able to click and drag the sun position manually by using the circular controllers around the house icon (both Azimuth and Altitude) with the right mouse button. This allowed for intuitive control by simply dragging the dot on the circle. The expected behavior is to drag the sun direction smoothly using the mouse over the circle area.
What are the steps to reproduce the issue?
Open SketchUp and launch Enscape.
Create or go to a saved View.
Open the View Management panel and enable “Save Enscape Sun Position.”
Try to drag the sun’s direction (Azimuth and Altitude) using the circular UI controls around the house icon.
Notice that the dot can only be moved if you click specifically on the line path — clicking directly on the dot or empty circular space no longer works as before.
This issue started occurring since the latest preview of version 4.8.0 and continues in the final release of 4.8.0.
