right click to minimise values no longer works
whether the rmc functionality was a mistake or not, vray now runs counter to how 3dsmax does. standardisation should be the way across compatible software. if you can get autodesk to change it`s functionality as well then that could also be a solution but as you say we have become used to it so it`s now our de facto standard.
as an example most software conforms to ctrl-c/ctrl-v for copy paste on windows and when someone decides their software is going to do it different it can be a right pain. imagine if after effects or other had `alt-shift-r` and `alt-shift k` for copy/paste because why not and then photoshop something different and microsoft word different again ? (i wouldn`t put it past adobe heh!).
a user shouldn`t need to remember different basic functionalities over many different software programs for the same purpose. something bespoke is obviously fine to create a new method for which is why the suggestion of shift-right click is a good example because it `adds` to the standard rather than rewriting it.
anthonyh
Ever noticed the checkbox by each layer?
EDIT: ah, for the textute influence you’ll have to use the keyboard, and type 0, followed by the enter key. A DEFAULT for a texture slot with a texture in it makes sense to be at 100%, not 0%, regardless of your opinion. Just saying.
EDIT #2: It’s also a THIRD of the work to re-enable a layer, by rmc, rather than typing 100, followed by the enter key, than typing 0 and enter is to a rmc.
Yeah please don’t fix what’s not broken. Default values could be shift + rightclick or similar.
It’s not going to change back.
Are you serious?
Anyway, wishlist thread because I have the need to speak up against this. Please vote here: https://forums.chaosgroup.com/showthread.php?94537-Right-click-on-spinners-Reset-to-0-instead-of-default-values&p=738655#post738655
hehe
anthonyh
It is perfectly coherent, you see.
The “argument” made in the form it was made is no argument: if you want to quote me, quote me entirely (with the two counter arguments.)
And yes, i am serious: i explained why that is, and why it’s been implemented.
The arguments against it, which would throw away work we find very precious, would have to be mightily strong ones.
Surely not “i prefer my spinners to zero out.”, which i thought i debunked a FEW posts back, in all honesty (and again above. It’s hard to call the big keypd 0 key plus the big keypad enter key a difficult combination to hit.).
@lele:
quote shortened for brevity only and was only intended as a bit of fun. it`s chaos` software and i guess you can do what you feel you like more. while your argument is valid so is the opposite, i explained in my post that if all software did this it would be chaos(pun intended) and a pain to remember all the unique shortcuts for each and every software for the same actions(maybe an extreme example but still valid).
apparently it has changed back partially ? i saw another thread about it. maybe in the nightlies ?
anthonyh
Ah, i sounded harsher than i intended (i’d have put a like or “ahah” in Fb to your post.).
I DID giggle, to my (puny) defense.
The fact that it isn’t everywhere yet is purely due to the time it takes to implement it across all the UIs, and/or some specific, outdated components (say, shaders) may have been skipped entirely.
While i do understand your argument about UIs, i am at pains at trying to see how a simple action like a rmc on a spinner returning optimal defaults (something max wouldn’t do, f.e., on successive object creation…) could be construed as overall detrimental.
Olli may cast back his mind to many years ago, when he was young and inexperienced, and such a feature was totally lacking.
The amount of enforcements (through pipeline diktats, scripted tools, scene sanity checkers, and so on), hours spent reviewing scene setups, hours more spent explaining to individual artists how and why some value should be left as origially found would have been spent being productive instead (“If in doubt, please RMC on the spinner. That is your safest bet.”).
I was on the side of the one having to write such tools, choose said rules, and explain the many bits of UI to users, as a TD -and the issue’s been very common for others in the same position over the years-, so i have quite vivid memories of late night firefighting, when the artists had left already.
With that in mind, if this ain’t a godsend, i don’t know what is.
Lele, I don’t want to annoy you, but let me give you a link to a video from the official 3dsMax learning channel, and listen closely to what she says. The same can be found in a 3dsMax book by Kelly Murdock called “Autodesk 3ds Max 2017 Complete Reference Guide”.
Really, I like you as a person, and I understand the point you made on a few pages back, but right clicking a spinner has to reset it to it’s minimum possible value. A value of 100% for the blend amount in the VrayBlendMTL is certainly not it’s minimum, you agree?
I have no idea how this relates to your statement here though, as I do not have any insight to the development of 3dsMax from decades ago.
to be fair the article says `resets to the lowest acceptable value` rather than explicitly stating zero so i`d say this could be open to interpretation. i admit i didn`t read past that so i may have missed something.
anthonyh
In my opinion now this is only a getting-used-to at first. When you think about it you actually have more value from it when it resets to a predefined (and hopefully good researched and acceptable) parameter, especially in render settings. Putting in a 0 you can do manually without thinking. Pulling a reasonable default value on the other hand is sometimes not so easy and therefore we have actually added value in having it behave like it does currently. Just my two cents.
Hate me but: I like it the way it is, with the default values. There is no reason for zeroing stuff like MSR or max subdiv.
+1 for going down to zero where it makes sense. Like for the progressive time limit and the memory limit though.
Thank you.
No, no i don’t agree.
Nor take anything but source material to validate my claims.
Your claimed ignorance doesn’t make your convictions any truer, i’m afraid.
Cfr. below, straight from the online Max manual :
[B]virtual [/B]void [B]SetResetValue ( float [I]v [/I])[/B]
[B]Remarks[/B]
A 3ds Max user may right click on the spinner buttons[I][B] to reset them to their 'reset' value (after they have been changed).[/B][/I] This method specifies the value used when the reset occurs.
[B]Parameters[/B]
[B]v [/B]   [I][B]The reset value.[/B][/I]
It goes without saying that not specifying v means “0”, or closer meaningful value (1, f.e.).
Liking me as a person is a very personal choice with little to no impact on my well being, or the effort i put into my work: don’t fret on it as it’s entirely optional. :wink:
this all began because there is a default time limit for the progressive renderer set to 1 minute, i think that`s really the only one that ever bothered me. set it to 0 as default so you can control it yourself and i`d probably be ok with the rest being whatever. i`m not sure what other values i`d zero but it was just slightly awkward having to set it to 0 each time. i can`t see why the 1 minute limit was there at default, does anybody have renders that quick(if so i want your pc and you can have mine).
anthonyh
Exactly !!
We thought it common, by now, for people to save their own render defaults in the “default” named v-ray preset (hence setting the renderer as one pleases, on load/reset. F.e. progressive time to 0.0).
The move to implement defaults on spinners’ RMC is something else entirely.
So Lele,
if you tell me that this is the way the right clicking behaviour is intended for 3dsMax, then most probably this is right. Sorry for the inconvenience. I am just baffled that the training material is entirely wrong on that part…
I don’t “tell”, i like to think i “show”.
I sincerely hope the difference isn’t lost to you.
