Here is a house I just sent off for approval.
Sorry for the small image. I have tried everything and uploads just don’t seem to work anymore for me.
Your tiny home looks lovely ![]()
Try to use sites like flickr, imgur.. Etc it allow you to upload higher res
btw looking nice butI think the reflection on the windows is a bit strong and dark
@glorybound Can you share the image file you’re trying to upload to support@chaosgroup.com and tell us which browser you’re using. Thanks
It’s all of his images - he’s mentioned problems with uploads in several threads.
Nice looking rendering Bobby. Only thing that sticks out to me is the minor amount of noticeable tiling in the wood pattern. Sometimes I like to rotate the gizmo just slightly off the x/y axis if it won’t affect the material (can’t do it with brick, tile, etc.) - that’ll obscure the tile pattern on the trim, though not so much on the garage door. Speaking of the garage door, there’s a curb at the base of your garage door.
Yes, it is all my uploads being an issue. I didn’t notice the wood tiling, but I’ll check it out. I did notice the concrete at the garage door and I’ll have to fix that. Thanks for the feedback.
Photo chopped the driveway to garage door
The problem with the small images should be fixed now guys.
Needs gutters. A pet peeve of mine is also stone corners that are razor sharp.
