Rock Wall
Hey all,
Just thought i would post this file to see if it might be useful to anyone. Its an early attempt in my r+d efforts for the next FXWARS over at cgtalk.
Heres a render:
And heres the file:
http://www.dwayneellis.com/misc/fxwars/RockWall-01.rar
The materials are just procedural, so you might want to paint up a custom texture or something.
Whoops…i forgot to mention that it recquires the Greeble plugin…and its a MAX 9 file with VRay 1.5.
Okay..i think thats it!!
thanks for sharing, great rocks!!!
thats supurb!
any chance of saving it for Max 8?
This would be really useful for me…
SV,
Heres a short little tutorial on how to do it.
http://www.dwayneellis.com/misc/fxwars/tutorial/Creating%20a%20Rock%20Wall.pdf
And all the screen caps are here:
http://www.dwayneellis.com/misc/fxwars/tutorial/01-FrontViewofBaseWallObject.jpg
http://www.dwayneellis.com/misc/fxwars/tutorial/02%20FrontViewofPolySelection.jpg
http://www.dwayneellis.com/misc/fxwars/tutorial/03-PerspectiveViewofNoiseModifier.jpg
http://www.dwayneellis.com/misc/fxwars/tutorial/04-PerspectiveViewofGeebleModifier.jpg
http://www.dwayneellis.com/misc/fxwars/tutorial/05-PerspectiveViewofSubdivideModifier.jpg
http://www.dwayneellis.com/misc/fxwars/tutorial/06-PerspectiveViewofTurbSmooth%20Modifier.jpg
http://www.dwayneellis.com/misc/fxwars/tutorial/07-PerspectiveViewofUVWMapModifier.jpg
http://www.dwayneellis.com/misc/fxwars/tutorial/08%20-PerspectiveViewofUVWMapping.jpg
http://www.dwayneellis.com/misc/fxwars/tutorial/09-PerspectiveViewofTestRender01.jpg
And heres another MAX file…version 9 unfortunatley.
http://www.dwayneellis.com/misc/fxwars/tutorial/Greeble-RockWall01.max
Cheers!
mate thats wonderful.
thank you ever so much, good stuff.
Looks pretty cool.
THanks alot.
thanx man!
that looks awesome…got to try it later on…max8here :?
:smile:
For those of you that have MAX 9…you should be able to select all the modifiers above the base editable poly on my rockwall…hold control and drag them onto the object you want to make into a rock wall. This will instance all the modifiers from my rockwall. Its going to guess at the poly select stuff but i’ve tried it a couple times on some arbitrary objects and it seems to work fine.
well that makes it even sweeter!
:smile:
Hmmmm…I wonder if you turned on the macro recorder while creating it you could generate a “Make RockWall” script? It could just be a button you click with the object selected. I’ll have to try this out.
Great stuff. Thanks very much for going to the effort.
Wall
That script didn’t work on my MAX 9. I am running MAX9 x64 on xp64… is that way it doesn’t work?
There is no script just yet…i was thinking that it might be possible to just record the actions in the maxscript listener while performing the short tutorial i made and then make a button out of it.
all the links are dead?
I would like to have a look at this.
Found it here, looks interesting :slight_smile:
http://www.nxtbook.com/nxtbooks/jam/augiworld0907/index.php?startid=22
